Einleitung
If your Walkman is working but you cannot play cassettes, you may need to replace the band that connects the film revolvers. This guide shows you how to do so.
Was du brauchst
Using a spudger, separate the back cover from the front.
Replace the band, ensuring that it wraps around both large plastic revolvers and the small metal one.
This picture shows how the belt was set when I opened a Walkman WM-FX10.
I think you can rely on the same arrangement in other Walkman's
8 weitere Nutzer:innen haben diese Anleitung absolviert.
