Einleitung
The speakers are responsible for outputting the audio of the tablet, but the speakers may deteriorate overtime. This could result in poor sound quality or no sound outputting at all. If that occurs, the speakers must be replaced. This guide will walk you through replacing the speakers.
Was du brauchst
Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
Work your way around the entire device by carefully prying and sliding the plastic opening tool.
Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
For each speaker remove the two 3-mm Phillips head screws using a Phillips #00 screwdriver.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
