Einleitung
The step-by-step guide for removing bObi's cover and screen. For help putting bObi back together, refer to: Closing bObi's Cover Post-Repair
Was du brauchst
Remove bObi’s front wheel to access one of the screws holding bObi together.
Uninstall the larger screw that sits deeper in the wheel compartment.
Remove bObi's dustbin.
Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
Lift the brush holder. To detach completely, unplug it from bObi.
Remove the two screws on the dustbin contact point holder inside bObi.
There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
Remove the four screws that secure bObi's screen and lift the whole piece out.
Put the replacement screen in the open space.
Re-install all four screws.
For a tutorial on closing bObi, see: Closing bObi's Cover Post-Repair
To reassemble your device, follow the guide for closing bObi, found here: Closing bObi's Cover Post-Repair
