Zum Hauptinhalt wechseln
HP Slate 8 Pro Speakers Replacement
Was du brauchst
  1. HP Slate 8 Pro Speakers Replacement, Remove back cover: Schritt 1, Bild 1 von 1
    • Use plastic opening tool to pry back panel off.
  2. HP Slate 8 Pro Speakers Replacement, Detach IO Board from system: Schritt 2, Bild 1 von 2 HP Slate 8 Pro Speakers Replacement, Detach IO Board from system: Schritt 2, Bild 2 von 2
    • Remove the orange and yellow ribbon cables.
    • detach the screws along the IO board
  3. HP Slate 8 Pro Speakers Replacement, Remove the IO board and the speakers: Schritt 3, Bild 1 von 1
    • Remove the IO board and the speakers circuit. Note that they are held together.
  4. HP Slate 8 Pro Speakers Replacement, Detach the speakers from the IO board.: Schritt 4, Bild 1 von 1
    • The tablet has two speakers. Each speaker is located to both sides of the IO board.
    • Detach the speakers from the cables that connect the speakers and the IO board. You will find more details in step 5 and 6.
  5. HP Slate 8 Pro Speakers Replacement, Remove the wires of the speakers from the IO board.: Schritt 5, Bild 1 von 1
    • To remove the cables that connect the speakers and the IO board, apply a subtle pressure to pull the cable out.
  6. HP Slate 8 Pro Speakers Replacement, Replace your speakers with the new parts: Schritt 6, Bild 1 von 2 HP Slate 8 Pro Speakers Replacement, Replace your speakers with the new parts: Schritt 6, Bild 2 von 2
    • Once you detach the speakers from the IO board, you should have three pieces as shown.
    • You are ready to replace the speakers.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jose Revelo
305 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 9-4, Blackwell Fall 2014 Mitglied von USF Tampa, Team 9-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 420
