Zum Hauptinhalt wechseln
Atari 5200 Motherboard Cleaning
Was du brauchst
  1. Atari 5200 Motherboard Cleaning, Atari 5200 Motherboard Cleaning: Schritt 1, Bild 1 von 1
    • Flip your Atari Entertainment System over to its top so you can see the bottom. You'll see seven screws holding your system together. Use a Philips #0 screwdriver to remove all seven screws.
  2. Atari 5200 Motherboard Cleaning: Schritt 2, Bild 1 von 1
    • Flip the Atari Entertainment System back over so that you can now see the top.
    • Use your hands to gently remove the top by sliding it off.
  3. Atari 5200 Motherboard Cleaning, Access: Granted: Schritt 3, Bild 1 von 1
    • You will now have access to the motherboard.
    • The motherboard can be cleaned with a moist paper towel.
    • Be sure the motherboard is fully dry before playing your Atari Entertainment System or you may damage it!
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 13-1, Staggers Fall 2014 Mitglied von USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Mitglieder
17 Anleitungen geschrieben
Ein Kommentar
This "tutorial" does not even cover gaining access to the motherboard.
Dannot - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 2,618
