Zum Hauptinhalt wechseln
IBM ThinkPad T42 Wi-Fi Card Replacement
Was du brauchst
  1. IBM ThinkPad T42 Wi-Fi Card Replacement, Bottom cover: Schritt 1, Bild 1 von 1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Wi-Fi Card Replacement, Rear screws: Schritt 2, Bild 1 von 1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
  3. IBM ThinkPad T42 Wi-Fi Card Replacement, Keyboard and Trackpad: Schritt 3, Bild 1 von 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Wi-Fi Card Replacement: Schritt 4, Bild 1 von 2 IBM ThinkPad T42 Wi-Fi Card Replacement: Schritt 4, Bild 2 von 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 5, Bild 1 von 1
    • To remove Wi-Fi card, first disconnect both display wires on the top right.
  6. IBM ThinkPad T42 Wi-Fi Card Replacement: Schritt 6, Bild 1 von 1
    • Then slide both of the metal pieces holding it down outwards, and it will pop up.
  7. IBM ThinkPad T42 Wi-Fi Card Replacement: Schritt 7, Bild 1 von 1
    • Carefully pull it out.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Kevin Rehm
472 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 29-76, Johann Spring 2010 Mitglied von Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Mitglieder
35 Anleitungen geschrieben
Ein Kommentar
Get the HMM for the laptop! On a few of these, I have had to just pull out the internal wi-fi card, and use a USB wi-fi adapter.
Martin Campbell - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 31
Insgesamt: 13,750
