Zum Hauptinhalt wechseln
Dell Inspiron 6000 Keyboard Replacement
Was du brauchst
  1. Dell Inspiron 6000 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 3 Dell Inspiron 6000 Keyboard Replacement, Keyboard: Schritt 3, Bild 2 von 3 Dell Inspiron 6000 Keyboard Replacement, Keyboard: Schritt 3, Bild 3 von 3
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
  4. Dell Inspiron 6000 Keyboard Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 6000 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Remove two 4 mm Philips #00 screws.
  5. Dell Inspiron 6000 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
  6. Dell Inspiron 6000 Keyboard Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron 6000 Keyboard Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron 6000 Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Gently pull the blue tab up until it comes away from computer.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Jacob DeWar
533 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 11-1, Blackwell Fall 2014 Mitglied von USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Hi there, my dell inspiron 6000 does not power up when I switch on. This happened after I remove my keypad to clean.. Any idea why?
John KAPA - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 2,077
