Zum Hauptinhalt wechseln
Nerf Dart Tag Furyfire Large Spring Replacement
Was du brauchst
  1. Nerf Dart Tag Furyfire Large Spring Replacement, Remove the screws: Schritt 1, Bild 1 von 1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Panel: Schritt 2, Bild 1 von 1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Black Cylinder: Schritt 3, Bild 1 von 1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: Schritt 4, Bild 1 von 2 Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: Schritt 4, Bild 2 von 2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
Abschluss
USF Tampa, Team 11-2, Blackwell Fall 2014 Mitglied von USF Tampa, Team 11-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 1,408
