Zum Hauptinhalt wechseln
Samsung SPH-A500 Logic Board Replacement
Was du brauchst
  1. Samsung SPH-A500 Logic Board Replacement, Logic Board: Schritt 1, Bild 1 von 1
    • Turn phone over
    • Push the gray tab above the battery forward to remove the battery.
  2. Samsung SPH-A500 Logic Board Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery from the phone, which will reveal four screws at the corners of the phone.
  3. Samsung SPH-A500 Logic Board Replacement: Schritt 3, Bild 1 von 1
    • Remove all four screws using a small Philips screwdriver.
    • Note: The screws do not need to be completely removed from the case, as long as they are unscrewed.
  4. Samsung SPH-A500 Logic Board Replacement: Schritt 4, Bild 1 von 1
    • Remove back cover by carefully prying it open.
    • Note: Some force may be required.
  5. Samsung SPH-A500 Logic Board Replacement: Schritt 5, Bild 1 von 1
    • Pull the side tabs outward while simultaneously lifting up the circuit board.
    • Do not completely pull out the circuit board.
  6. Samsung SPH-A500 Logic Board Replacement: Schritt 6, Bild 1 von 1
    • Look for the clip at the top right corner of the logic board.
  7. Samsung SPH-A500 Logic Board Replacement: Schritt 7, Bild 1 von 1
    • Remove the clip from the logic board.
  8. Samsung SPH-A500 Logic Board Replacement: Schritt 8, Bild 1 von 1
    • Remove the logic board.
    • Replace the broken logic board with a new one.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 18-100, Johann Spring 2010 Mitglied von Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 2,033
