Zum Hauptinhalt wechseln
Blu Studio HD 6.0 MicroSD Card Replacement
Was du brauchst
  1. Blu Studio HD 6.0 MicroSD Card Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 MicroSD Card Replacement, Back Panel.: Schritt 2, Bild 1 von 2 Blu Studio HD 6.0 MicroSD Card Replacement, Back Panel.: Schritt 2, Bild 2 von 2
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 MicroSD Card Replacement: Schritt 3, Bild 1 von 2 Blu Studio HD 6.0 MicroSD Card Replacement: Schritt 3, Bild 2 von 2
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 MicroSD Card Replacement, Insert the Micro-SD Card: Schritt 4, Bild 1 von 3 Blu Studio HD 6.0 MicroSD Card Replacement, Insert the Micro-SD Card: Schritt 4, Bild 2 von 3 Blu Studio HD 6.0 MicroSD Card Replacement, Insert the Micro-SD Card: Schritt 4, Bild 3 von 3
    • Find the Micro-SD card slot which is under the right SIM card slot.
    • Line up the gold pins of the Micro-SD card with the pins of the card slot. If pins in the slot are hidden, then insert the Micro-SD card with the "MicroSD" print up and the pins facing the slot.
    • Slide the card into the slot until you either hear a clicking noise or until the card does not move anymore. Do not apply too much force; gently slide it in and stop immediately when it does not move anymore.
  5. Blu Studio HD 6.0 MicroSD Card Replacement, Turn the phone on: Schritt 5, Bild 1 von 1
    • Your phone should boot up and ask you to format your Micro-SD Card.
    • Format the card and you're good to go.
    • If your phone does not recognize the card, ensure that the gold pins of the card aligned with the gold pins on the phone's Micro-SD slot.
    • If the card is installed correctly, the card may be faulty. If so contact the Micro-SD card manufacturer.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Alec
617 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 9-1, Blackwell Fall 2014 Mitglied von USF Tampa, Team 9-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G1
3 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Very clear instructions and step by step guidance
Laszlo Tihanyi - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 16,296
