Zum Hauptinhalt wechseln
HP Slate 8 Pro Microphone Replacement
Was du brauchst
  1. HP Slate 8 Pro Microphone Replacement, Remove the back cover: Schritt 1, Bild 1 von 1
    • Before opening your device, turn off the tablet. If you are unsure whether the tablet is off or in Hibernation, turn the tablet on, and then shut it down through the operating system.
    • Unplug your tablet from any power supply
    • Remove all external devices.
    • Remove back cover with plastic tools to avoid scratching the screen.
  2. HP Slate 8 Pro Microphone Replacement, Remove screws: Schritt 2, Bild 1 von 1
    • Remove all screws from the sides of the battery
  3. HP Slate 8 Pro Microphone Replacement, Disconnect the battery cable: Schritt 3, Bild 1 von 1
    • Disconnect the battery cable from the system board.
    • Use a little bit of pressure to remove the cable.
  4. HP Slate 8 Pro Microphone Replacement, Remove ZIF connector: Schritt 4, Bild 1 von 1
    • Release the ZIF connector to which the microphone cable is attached
  5. HP Slate 8 Pro Microphone Replacement, Remove the  microphone: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove microphone from panel using tweezers
    • Add your new microphone
Abschluss
Claudia
246 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 9-4, Blackwell Fall 2014 Mitglied von USF Tampa, Team 9-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 401
