Zum Hauptinhalt wechseln
AlphaSmart Pro Front Panel Replacement
Was du brauchst
  1. AlphaSmart Pro Front Panel Replacement, Separating Panels: Schritt 1, Bild 1 von 3 AlphaSmart Pro Front Panel Replacement, Separating Panels: Schritt 1, Bild 2 von 3 AlphaSmart Pro Front Panel Replacement, Separating Panels: Schritt 1, Bild 3 von 3
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
  2. AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: Schritt 2, Bild 1 von 2 AlphaSmart Pro Front Panel Replacement, Detaching Ribbon Cable: Schritt 2, Bild 2 von 2
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
    • You are now able to separate the front panel from the back panel.
  3. AlphaSmart Pro Front Panel Replacement, Removing Display Screen: Schritt 3, Bild 1 von 3 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: Schritt 3, Bild 2 von 3 AlphaSmart Pro Front Panel Replacement, Removing Display Screen: Schritt 3, Bild 3 von 3
    • Looking at the front panel, use the Phillips #00 screwdriver to remove the four Phillips head 0.8 cm screws from each corner of the display motherboard.
    • Lift the display screen and motherboard from the plastic front panel to separate the two pieces.
Abschluss
Nathan Smith
22 Reputation
2 Anleitungen geschrieben
Clemson, Team 1-1, Benson Fall 2014 Mitglied von Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 251
