Zum Hauptinhalt wechseln
Canon PowerShot A4000 IS SD Card Replacement
Was du brauchst
  1. Canon PowerShot A4000 IS SD Card Replacement, Reinserting Memory Card: Schritt 1, Bild 1 von 1
    • The inside of your Canon PowerShot A4000 camera should have a picture showing how to reinsert your memory card.
    • Line the memory card up like it is shown in the camera and using your thumb, press down on the card until you hear a click. Your memory card is now back in place and ready for use.
  2. Canon PowerShot A4000 IS SD Card Replacement, Memory Card Removal: Schritt 2, Bild 1 von 2 Canon PowerShot A4000 IS SD Card Replacement, Memory Card Removal: Schritt 2, Bild 2 von 2
    • To open the battery compartment where the memory card is stored, refer to the Battery Replacement Guide.
    • The memory card is stored behind the battery on the side opposite of the lens as outlined by the red rectangle in the picture.
    • To remove the memory card, use your thumb to press down on the exposed part of the card.
    • The card will dip down further into the compartment and then you will hear a click as the card is released.
Abschluss
Clemson, Team 1-3, Benson Fall 2014 Mitglied von Clemson, Team 1-3, Benson Fall 2014
CLEM-BENSON-F14S1G3
3 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 17
Insgesamt: 799
