Zum Hauptinhalt wechseln
KitchenAid KSB5CR Power Cable Replacement
Was du brauchst
  1. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: Schritt 1, Bild 1 von 3 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: Schritt 1, Bild 2 von 3 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: Schritt 1, Bild 3 von 3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 2: Schritt 2, Bild 1 von 1
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Power Cable Replacement, Freeing the Power Cable: Schritt 3, Bild 1 von 1
    • Lift up on the power cable to pop it out of its holder.
  4. KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: Schritt 4, Bild 1 von 2 KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: Schritt 4, Bild 2 von 2
    • Be gentle with the knife or you will break the circuit board.
    • Slide the knife into the metal loop holding the insulation before the white copper wire, and wiggle it back and forth until it loosens.
    • Pull the wire out from the metal loop that you loosened.
    • Repeat this process with the black copper wire.
  5. KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: Schritt 5, Bild 1 von 2 KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: Schritt 5, Bild 2 von 2
    • Using the Phillips #2 screwdriver, remove the #8 Phillips 6mm screw to which the green wire is attached.
Abschluss
Cal Poly, Team 12-5, Forte Fall 2014 Mitglied von Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 662
