Zum Hauptinhalt wechseln
Polaroid Onestep Close Up Shutter Switch Replacement
Was du brauchst
  1. Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: Schritt 1, Bild 1 von 3 Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: Schritt 1, Bild 2 von 3 Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: Schritt 1, Bild 3 von 3
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Polaroid Onestep Close Up Shutter Switch Replacement, Opening Film Tray: Schritt 2, Bild 1 von 2 Polaroid Onestep Close Up Shutter Switch Replacement, Opening Film Tray: Schritt 2, Bild 2 von 2
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: Schritt 3, Bild 1 von 3 Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: Schritt 3, Bild 2 von 3 Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: Schritt 3, Bild 3 von 3
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: Schritt 4, Bild 1 von 3 Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: Schritt 4, Bild 2 von 3 Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: Schritt 4, Bild 3 von 3
    • After the face plate is off, the shutter switch should slide out easily.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Tyler OBrien
627 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 3-5, Brown Fall 2014 Mitglied von USF Tampa, Team 3-5, Brown Fall 2014
USFT-BROWN-F14S3G5
3 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
where did you get the replacement parts for this?
Jacob Sokolove - Antwort
I’d love to find a new shutter piece..
Joni Korkkula - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 20
Insgesamt: 3,920
