Zum Hauptinhalt wechseln
Fosera Scandle 200 Battery Replacement
Was du brauchst
  1. Fosera Scandle 200 Battery Replacement, Motherboard Removal: Schritt 1, Bild 1 von 1
    • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
  2. Fosera Scandle 200 Battery Replacement: Schritt 2, Bild 1 von 1
    • Gently separate the two halves of the casing.
  3. Fosera Scandle 200 Battery Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
    • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
  4. Fosera Scandle 200 Battery Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
  5. Fosera Scandle 200 Battery Replacement: Schritt 5, Bild 1 von 1
    • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
  6. Fosera Scandle 200 Battery Replacement, Battery: Schritt 6, Bild 1 von 1
    • Remove the four #0 15mm screws to release the battery housing from the case.
  7. Fosera Scandle 200 Battery Replacement: Schritt 7, Bild 1 von 1
    • Take the battery housing and battery out of the casing.
Abschluss
USF Tampa, Team 12-5, Blackwell Fall 2014 Mitglied von USF Tampa, Team 12-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G5
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 610
