Zum Hauptinhalt wechseln
Air Blasters Tek Six Reload Slider Spring Replacement
Was du brauchst
  1. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: Schritt 1, Bild 1 von 3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: Schritt 1, Bild 2 von 3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw of the grey slider: Schritt 1, Bild 3 von 3
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: Schritt 2, Bild 1 von 3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: Schritt 2, Bild 2 von 3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screws in main body: Schritt 2, Bild 3 von 3
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: Schritt 3, Bild 1 von 3 Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: Schritt 3, Bild 2 von 3 Air Blasters Tek Six Reload Slider Spring Replacement, Take the main body apart: Schritt 3, Bild 3 von 3
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  4. Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: Schritt 4, Bild 1 von 3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: Schritt 4, Bild 2 von 3 Air Blasters Tek Six Reload Slider Spring Replacement, Remove metal pin: Schritt 4, Bild 3 von 3
    • Carefully grab the metal pin keeping the air system and top spring, and slide it outwards. This will release the air system with the plunger completely.
  5. Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw holding the top spring to reload slider: Schritt 5, Bild 1 von 2 Air Blasters Tek Six Reload Slider Spring Replacement, Remove screw holding the top spring to reload slider: Schritt 5, Bild 2 von 2
    • Using a screwdriver, remove the 7.5 mm phillips 00 screw holding the top spring to the reload slider.
Abschluss
USF Tampa, Team 3-1, Brown Fall 2014 Mitglied von USF Tampa, Team 3-1, Brown Fall 2014
USFT-BROWN-F14S3G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 434
