Einleitung
The reload slider spring brings the reload slider back to the front once the blaster is ready to fire.
Was du brauchst
Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
Remove grey slider from the main body of the blaster.
Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
Carefully grab the metal pin keeping the air system and top spring, and slide it outwards. This will release the air system with the plunger completely.
Using a screwdriver, remove the 7.5 mm phillips 00 screw holding the top spring to the reload slider.
