Einleitung
This guide will demonstrate how to access the TONE knob or VOLUME knob and replace it.
Was du brauchst
Press down on the two tabs at the top of the door.
Rotate the door away from the radio, towards you.
Lift the door out of the three smaller tabs on the bottom.
Push the batteries against the spring and pull out using your finger to remove them.
Remove the 6 screws (30 mm in length) with the Phillips #2 Screwdriver from the large holes marked by arrows on the radio.
Grasp the radio from the front and back halves and gently pull apart to separate them.
Pull the white plug out from the red outlet in the Orange circuit board in the back face of the casing.
Push upwards against bottom edge of the knob connection with a flat head screwdriver until the knob pops off.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
