Zum Hauptinhalt wechseln
Automatic Tommy 20 Ammo Drum Replacement
Was du brauchst
  1. Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: Schritt 1, Bild 1 von 2 Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: Schritt 1, Bild 2 von 2
    • Locate the orange slider on the front side of the gun.
    • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
  2. Automatic Tommy 20 Ammo Drum Replacement: Schritt 2, Bild 1 von 3 Automatic Tommy 20 Ammo Drum Replacement: Schritt 2, Bild 2 von 3 Automatic Tommy 20 Ammo Drum Replacement: Schritt 2, Bild 3 von 3
    • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
    • Remove all parts within the chamber to be able to completely detach the nose of the gun.
    • Be careful to keep track of all the components for reassembly.
  3. Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: Schritt 3, Bild 1 von 3 Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: Schritt 3, Bild 2 von 3 Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: Schritt 3, Bild 3 von 3
    • Remove the 1/16 in. screws using a Phillips #00 Screwdriver as indicated in the photo on the left.
    • Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left.
  4. Automatic Tommy 20 Ammo Drum Replacement: Schritt 4, Bild 1 von 1
    • Carefully spread apart the two halves of the gun, and lift out the ammo drum.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Moira Foster
419 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 6-22, Maness Fall 2014 Mitglied von Cal Poly, Team 6-22, Maness Fall 2014
CPSU-MANESS-F14S6G22
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 763
