Zum Hauptinhalt wechseln
How to clean the Avanti 308YWT evaporator pan
  1. How to clean the Avanti 308YWT evaporator pan, How to clean the Avanti 308YWT evaporator pan: Schritt 1, Bild 1 von 1
    • Before starting, unplug the refrigerator.
  2. How to clean the Avanti 308YWT evaporator pan: Schritt 2, Bild 1 von 1
    • Go to the bottom of the back side of the refrigerator and locate the cut out where the compressor and evaporator are stored.
  3. How to clean the Avanti 308YWT evaporator pan: Schritt 3, Bild 1 von 1
    • Remove the evaporator tray by simply pulling up and out the tray. make sure that none of the liquid spills.
  4. How to clean the Avanti 308YWT evaporator pan: Schritt 4, Bild 1 von 2 How to clean the Avanti 308YWT evaporator pan: Schritt 4, Bild 2 von 2
    • The evaporator tray might have ice build up on it. You can remove this ice by pouring warm water on the tray. After the ice is melted, clean the tray with warm water and soap.
  5. How to clean the Avanti 308YWT evaporator pan: Schritt 5, Bild 1 von 1
    • Dry and reinsert the tray.
  6. How to clean the Avanti 308YWT evaporator pan: Schritt 6, Bild 1 von 1
    • Plug the refrigerator back in.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Seye
371 Reputation
1 Anleitung geschrieben
USF Tampa, Team 1-38, Donnelly Fall 2014 Mitglied von USF Tampa, Team 1-38, Donnelly Fall 2014
USFT-DONNELLY-F14S1G38
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 44
Insgesamt: 3,515
