Zum Hauptinhalt wechseln
iPod Shuffle 3rd Generation Rear Case Replacement
Was du brauchst
  1. iPod Shuffle 3rd Generation Rear Case Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
    • Be careful when using a metal spudger, as you may scratch the outer case.
  2. iPod Shuffle 3rd Generation Rear Case Replacement: Schritt 2, Bild 1 von 2 iPod Shuffle 3rd Generation Rear Case Replacement: Schritt 2, Bild 2 von 2
    • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  3. iPod Shuffle 3rd Generation Rear Case Replacement: Schritt 3, Bild 1 von 1
    • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
    • Pry the rear case away from the front case.
  4. iPod Shuffle 3rd Generation Rear Case Replacement: Schritt 4, Bild 1 von 1
    • Lift the bottom of the rear case and remove it from the rest of the iPod.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Matthew Newsom
39.527 Reputation
67 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 33
Insgesamt: 8,116
