Zum Hauptinhalt wechseln
iPod Shuffle 3rd Generation Logic Board Replacement
Was du brauchst
  1. iPod Shuffle 3rd Generation Logic Board Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
    • Be careful when using a metal spudger, as you may scratch the outer case.
  2. iPod Shuffle 3rd Generation Logic Board Replacement: Schritt 2, Bild 1 von 2 iPod Shuffle 3rd Generation Logic Board Replacement: Schritt 2, Bild 2 von 2
    • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  3. iPod Shuffle 3rd Generation Logic Board Replacement: Schritt 3, Bild 1 von 1
    • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
    • Pry the rear case away from the front case.
  4. iPod Shuffle 3rd Generation Logic Board Replacement: Schritt 4, Bild 1 von 1
    • Lift the bottom of the rear case and remove it from the rest of the iPod.
  5. iPod Shuffle 3rd Generation Logic Board Replacement, Logic Board: Schritt 5, Bild 1 von 1
    • Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
  6. iPod Shuffle 3rd Generation Logic Board Replacement: Schritt 6, Bild 1 von 1
    • Remove the single Phillips screw securing the logic board to the front case.
  7. iPod Shuffle 3rd Generation Logic Board Replacement: Schritt 7, Bild 1 von 1
    • Peel the battery up from the front case with an iPod opening tool.
    • Remove the logic board and battery from the iPod.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Matthew Newsom
39.527 Reputation
67 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 6,427
