Zum Hauptinhalt wechseln
Polycom SoundStation Back Housing Replacement
Was du brauchst
  1. Polycom SoundStation Back Housing Replacement, Back Housing: Schritt 1, Bild 1 von 1
    • Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
    • Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
  2. Polycom SoundStation Back Housing Replacement: Schritt 2, Bild 1 von 2 Polycom SoundStation Back Housing Replacement: Schritt 2, Bild 2 von 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
Abschluss
USF Sarasota-Manatee, Team 1-3, Stewart Fall 2014 Mitglied von USF Sarasota-Manatee, Team 1-3, Stewart Fall 2014
USFSM-STEWART-F14S1G3
3 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
thanks for this - the 7mm were under footpads so I couldn’t see them. cover now off, keyboard dried of coffee and working fine again!!
J M - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 16
Insgesamt: 1,165
