Zum Hauptinhalt wechseln
Toshiba Excite 10 AT300 Rear-Facing Camera Replacement
Was du brauchst
  1. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove SD Card: Schritt 1, Bild 1 von 1
    • Remove the SD card from the SD card slot.
  2. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Open the Tablet: Schritt 2, Bild 1 von 3 Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Open the Tablet: Schritt 2, Bild 2 von 3 Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Open the Tablet: Schritt 2, Bild 3 von 3
    • Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
    • Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet.
  3. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Disconnect Speaker Wires: Schritt 3, Bild 1 von 3 Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Disconnect Speaker Wires: Schritt 3, Bild 2 von 3 Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Disconnect Speaker Wires: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the speaker cable from its socket by gripping both sides of the white connector piece with tweezers and pulling straight out.
    • Be careful not to rip the wires out of the white connector piece.
  4. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove Screws: Schritt 4, Bild 1 von 2 Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove Screws: Schritt 4, Bild 2 von 2
    • Using a #00 Phillips screwdriver, remove the following screws:
    • Five 3mm Phillips #00 screws
  5. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove Battery Cable: Schritt 5, Bild 1 von 3 Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove Battery Cable: Schritt 5, Bild 2 von 3 Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove Battery Cable: Schritt 5, Bild 3 von 3
    Kaufen
    • Gently lift the battery, pulling away from the tab holding it in place at the bottom.
    • While holding the battery up, use a pair of tweezers to remove the battery cable from its connector.
  6. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove screw and yellow tape: Schritt 6, Bild 1 von 1
    Kaufen
    • Using a #00 Philips screwdriver, remove the screw attaching daughter board.
    • Remove the yellow tape using a pair of tweezers.
  7. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove Ribbon Cable: Schritt 7, Bild 1 von 3 Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove Ribbon Cable: Schritt 7, Bild 2 von 3 Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove Ribbon Cable: Schritt 7, Bild 3 von 3
    • Unlock the ribbon cable housing using tweezers and/or a spudger.
    • Gently pull the ribbon cable out of its housing using the tweezers or your hands.
  8. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove copper foil wires: Schritt 8, Bild 1 von 3 Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove copper foil wires: Schritt 8, Bild 2 von 3 Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove copper foil wires: Schritt 8, Bild 3 von 3
    • Pull copper tape away from the back, keeping it connected to the green rear camera board.
    • Be careful not to rip the copper tape.
  9. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove the daughter board: Schritt 9, Bild 1 von 2 Toshiba Excite 10 AT300 Rear-Facing Camera Replacement, Remove the daughter board: Schritt 9, Bild 2 von 2
    • Using your hands remove daughter board by lifting it off of the tablet chassis. Flip it over and place it next to the tablet face-down.
    • Do not disconnect the red and black wires connecting it to the vibrating mechanism.
  10. Toshiba Excite 10 AT300 Rear-Facing Camera Replacement: Schritt 10, Bild 1 von 2 Toshiba Excite 10 AT300 Rear-Facing Camera Replacement: Schritt 10, Bild 2 von 2
    • Gently pinch the ribbon cable connector between two fingers or with tweezers and pull it straight outwards. The ribbon cable connector should disconnect and the camera can now be replaced.
Abschluss
Gus Holz
297 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 14-26, Maness Fall 2014 Mitglied von Cal Poly, Team 14-26, Maness Fall 2014
CPSU-MANESS-F14S14G26
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 513
