Zum Hauptinhalt wechseln
AlphaSmart Pro Display Screen Replacement
Was du brauchst
  1. AlphaSmart Pro Display Screen Replacement, Separating Panels: Schritt 1, Bild 1 von 3 AlphaSmart Pro Display Screen Replacement, Separating Panels: Schritt 1, Bild 2 von 3 AlphaSmart Pro Display Screen Replacement, Separating Panels: Schritt 1, Bild 3 von 3
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
  2. AlphaSmart Pro Display Screen Replacement, Detaching Ribbon Cable: Schritt 2, Bild 1 von 2 AlphaSmart Pro Display Screen Replacement, Detaching Ribbon Cable: Schritt 2, Bild 2 von 2
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
    • You are now able to separate the front panel from the back panel.
  3. AlphaSmart Pro Display Screen Replacement, Removing Display Screen: Schritt 3, Bild 1 von 3 AlphaSmart Pro Display Screen Replacement, Removing Display Screen: Schritt 3, Bild 2 von 3 AlphaSmart Pro Display Screen Replacement, Removing Display Screen: Schritt 3, Bild 3 von 3
    • Looking at the front panel, use the Phillips #00 screwdriver to remove the four Phillips head 0.8 cm screws from each corner of the display motherboard.
    • Lift the display screen and motherboard from the plastic front panel to separate the two pieces.
  4. AlphaSmart Pro Display Screen Replacement, Removing Small Motherboard: Schritt 4, Bild 1 von 3 AlphaSmart Pro Display Screen Replacement, Removing Small Motherboard: Schritt 4, Bild 2 von 3 AlphaSmart Pro Display Screen Replacement, Removing Small Motherboard: Schritt 4, Bild 3 von 3
    • To remove the small motherboard from the display screen, use the flat needle nose pliers or the angled tweezers to carefully bend the 12 metal tabs so that they can be pushed through the small slots.
    • You must also lift up the transparent tape that covers two of these tabs.
    • Separate the display screen and small motherboard.
Abschluss
Nathan Smith
22 Reputation
2 Anleitungen geschrieben
Clemson, Team 1-1, Benson Fall 2014 Mitglied von Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 27
Insgesamt: 566
