Zum Hauptinhalt wechseln
Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement
Was du brauchst
  1. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: Schritt 2, Bild 1 von 2 Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement, Front and Rear Casing: Schritt 3, Bild 1 von 2 Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement, Front and Rear Casing: Schritt 3, Bild 2 von 2
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: Schritt 4, Bild 1 von 1
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: Schritt 5, Bild 1 von 1
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: Schritt 6, Bild 1 von 1
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: Schritt 7, Bild 1 von 1
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: Schritt 8, Bild 1 von 1
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: Schritt 9, Bild 1 von 2 Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: Schritt 9, Bild 2 von 2
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
Abschluss
Taylor Shields
846 Reputation
8 Anleitungen geschrieben
Clemson, Team 2-1, Benson Fall 2014 Mitglied von Clemson, Team 2-1, Benson Fall 2014
CLEM-BENSON-F14S2G1
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 196
