Zum Hauptinhalt wechseln
Atari 5200 Controller Side Buttons Replacement
Was du brauchst
  1. Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: Schritt 1, Bild 1 von 3 Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: Schritt 1, Bild 2 von 3 Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: Schritt 1, Bild 3 von 3
    • Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
  2. Atari 5200 Controller Side Buttons Replacement, A Little Off the Sides: Schritt 2, Bild 1 von 2 Atari 5200 Controller Side Buttons Replacement, A Little Off the Sides: Schritt 2, Bild 2 von 2
    • Now that the top of the controller is exposed, the orange, side buttons can easily slide out.
    • Realign the buttons over the sensors/clean the sensor contacts.
    • Be careful when reassembling your buttons. Make sure the black buttons are aligned properly over the silver sensors on the flex board
    • Also, be careful to properly align the bottom of the joystick with the pots (white levers)
  3. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 1: Schritt 3, Bild 1 von 2 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 1: Schritt 3, Bild 2 von 2
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
  4. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 2: Schritt 4, Bild 1 von 2 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 2: Schritt 4, Bild 2 von 2
    • Pull the circuit strip through the new space.
    • Realign the top and bottom of the controller.
  5. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: Schritt 5, Bild 1 von 3 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: Schritt 5, Bild 2 von 3 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: Schritt 5, Bild 3 von 3
    • Return the buttons to the top of the controller.
    • Snap the frame back into place.
    • Screw the screws.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Alan Abelson
233 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 13-1, Staggers Fall 2014 Mitglied von USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 1,022
