Zum Hauptinhalt wechseln
Verizon M1424WR Motherboard Replacement
Was du brauchst
  1. Verizon M1424WR Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Flip the device so that the bottom is facing up.
  2. Verizon M1424WR Motherboard Replacement: Schritt 2, Bild 1 von 3 Verizon M1424WR Motherboard Replacement: Schritt 2, Bild 2 von 3 Verizon M1424WR Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Warning: The design and location of the plastic clips holding this shroud make it extremely difficult to release. Take your time and use a second pry tool if necessary.
    • Insert the plastic-opening tool under the silver labeled casing.
    • Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
  3. Verizon M1424WR Motherboard Replacement: Schritt 3, Bild 1 von 2 Verizon M1424WR Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
  4. Verizon M1424WR Motherboard Replacement: Schritt 4, Bild 1 von 2 Verizon M1424WR Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
  5. Verizon M1424WR Motherboard Replacement: Schritt 5, Bild 1 von 3 Verizon M1424WR Motherboard Replacement: Schritt 5, Bild 2 von 3 Verizon M1424WR Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Locate the two 10-mm screws on either side of the circuit board.
    • Unscrew the two 10-mm screws using a Phillips #0 screwdriver.
    • Keep track of the red rubber washer you remove from underneath one of the screws.
  6. Verizon M1424WR Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Lift the front of the circuit board up from the bottom casing.
  7. Verizon M1424WR Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Pull the circuit board towards you until it is separate from the bottom casing.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jeffrey Fox
347 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 763
