Zum Hauptinhalt wechseln
Dremel MultiPro 395 Casing Replacement
Was du brauchst
  1. Dremel MultiPro 395 Casing Replacement, Casing: Schritt 1, Bild 1 von 2 Dremel MultiPro 395 Casing Replacement, Casing: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Kaufen
    • Remove the blue caps located on either side of the MultiPro, using a 3 mm flathead screwdriver.
  2. Dremel MultiPro 395 Casing Replacement: Schritt 2, Bild 1 von 2 Dremel MultiPro 395 Casing Replacement: Schritt 2, Bild 2 von 2
    • Carefully remove the carbon brushes attached at the end of the springs by gently pulling on the springs using your hands.
  3. Dremel MultiPro 395 Casing Replacement: Schritt 3, Bild 1 von 2 Dremel MultiPro 395 Casing Replacement: Schritt 3, Bild 2 von 2
    • Pull one side of the hanger up and then pull away from the Multipro until the other side can be pulled out.
  4. Dremel MultiPro 395 Casing Replacement: Schritt 4, Bild 1 von 3 Dremel MultiPro 395 Casing Replacement: Schritt 4, Bild 2 von 3 Dremel MultiPro 395 Casing Replacement: Schritt 4, Bild 3 von 3
    • Remove the 4 screws located on the bottom of the Multipro with a T15 screwdriver.
  5. Dremel MultiPro 395 Casing Replacement: Schritt 5, Bild 1 von 3 Dremel MultiPro 395 Casing Replacement: Schritt 5, Bild 2 von 3 Dremel MultiPro 395 Casing Replacement: Schritt 5, Bild 3 von 3
    • Hold down the collet lock, remove the chuck cap from the top of the Multipro by screwing counterclockwise.
  6. Dremel MultiPro 395 Casing Replacement: Schritt 6, Bild 1 von 3 Dremel MultiPro 395 Casing Replacement: Schritt 6, Bild 2 von 3 Dremel MultiPro 395 Casing Replacement: Schritt 6, Bild 3 von 3
    • Remove the black housing cap from the Multipro located directly below the chuck cap.
  7. Dremel MultiPro 395 Casing Replacement: Schritt 7, Bild 1 von 3 Dremel MultiPro 395 Casing Replacement: Schritt 7, Bild 2 von 3 Dremel MultiPro 395 Casing Replacement: Schritt 7, Bild 3 von 3
    • Pull the bottom side of the casing up to remove it.
  8. Dremel MultiPro 395 Casing Replacement: Schritt 8, Bild 1 von 3 Dremel MultiPro 395 Casing Replacement: Schritt 8, Bild 2 von 3 Dremel MultiPro 395 Casing Replacement: Schritt 8, Bild 3 von 3
    • Gently lift the motor shaft out of the Multipro.
  9. Dremel MultiPro 395 Casing Replacement: Schritt 9, Bild 1 von 3 Dremel MultiPro 395 Casing Replacement: Schritt 9, Bild 2 von 3 Dremel MultiPro 395 Casing Replacement: Schritt 9, Bild 3 von 3
    • Pull the lock pin and its casing out of the other side of the Multipro case.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
A link to parts is always nice,
bari - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 23
Insgesamt: 2,135
