Zum Hauptinhalt wechseln
SodaStream Fountain Jet A200 Spring Replacement
  1. SodaStream Fountain Jet A200 Spring Replacement, removing back cover: Schritt 1, Bild 1 von 2 SodaStream Fountain Jet A200 Spring Replacement, removing back cover: Schritt 1, Bild 2 von 2
    • Press in the two gray buttons found on either side, at the top of the machine.
    • Pull back on the cover until it releases from the device and pull the back off.
  2. SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: Schritt 2, Bild 1 von 2 SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: Schritt 2, Bild 2 von 2
    • Place your hand under the carbonation button and gently pull up and away from you, towards the back of the machine.
  3. SodaStream Fountain Jet A200 Spring Replacement, spring removal: Schritt 3, Bild 1 von 2 SodaStream Fountain Jet A200 Spring Replacement, spring removal: Schritt 3, Bild 2 von 2
    • Remove the spring located under the carbonation button.
    • Replace with the new spring, by lining it up and pushing it down.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Does anyone know where I can get a carbonation button?
draganr@wi.rr.com
draganr - Antwort
Do we know the spring parameters?
Outside Diameter
Inside Diameter
Overall Length
Wire Diameter
Total # of Coils
Active # of Coils
Solid Height
Space between the Coils
John Friedman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 45
Insgesamt: 9,908
