Zum Hauptinhalt wechseln
Samsung Galaxy Fame S6812i Camera Replacement
Was du brauchst
  1. Samsung Galaxy Fame S6812i Camera Replacement, Remove the battery cover: Schritt 1, Bild 1 von 1
    • Turn the phone off and make sure your hands are clean. Use your thumb nail or a plastic spudger to pry open the back cover,
  2. Samsung Galaxy Fame S6812i Camera Replacement, Remove the battery: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool or your thumb nail to lift the battery out of the receptacle.
  3. Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: Schritt 3, Bild 1 von 3 Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: Schritt 3, Bild 2 von 3 Samsung Galaxy Fame S6812i Camera Replacement, Removing screws and stickers: Schritt 3, Bild 3 von 3
    • Remove the five 4 mm screws with a Phillips#00 screwdriver.
    • Make sure you remove the sticker hiding the screw on the left bottom corner.
  4. Samsung Galaxy Fame S6812i Camera Replacement, Removing the mid-frame.: Schritt 4, Bild 1 von 2 Samsung Galaxy Fame S6812i Camera Replacement, Removing the mid-frame.: Schritt 4, Bild 2 von 2
    • Using the plastic opening tool pry into the bezel to remove the mid-frame
    • Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Be gentle the plastic mounting clips are very fragile. Pay extra attention when working around the volume button.
  5. Samsung Galaxy Fame S6812i Camera Replacement: Schritt 5, Bild 1 von 1
    • After separating the two frames, you will have access to the camera
  6. Samsung Galaxy Fame S6812i Camera Replacement: Schritt 6, Bild 1 von 1
    • Pull the camera off the system by using the tweezers. Perform this step with caution.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Charles
133 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 8-2, Leahy Fall 2014 Mitglied von USF Tampa, Team 8-2, Leahy Fall 2014
USFT-LEAHY-F14S8G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 993
