Zum Hauptinhalt wechseln
LG G3 Battery Replacement
Was du brauchst
  1. LG G3 Battery Replacement, Back Cover: Schritt 1, Bild 1 von 2 LG G3 Battery Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Battery Replacement: Schritt 2, Bild 1 von 2 LG G3 Battery Replacement: Schritt 2, Bild 2 von 2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Battery Replacement, Battery: Schritt 3, Bild 1 von 2 LG G3 Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Battery Replacement: Schritt 4, Bild 1 von 2 LG G3 Battery Replacement: Schritt 4, Bild 2 von 2
    • Lift the battery out of its recess and remove it.
Abschluss
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
21 weitere Nutzer:innen haben diese Anleitung absolviert.
Dominik Schnabelrauch
202.758 Reputation
682 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.732 Anleitungen geschrieben
Ein Kommentar
Thank you very much!
ItayDigital - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 19
Insgesamt: 17,567
