Zum Hauptinhalt wechseln
Nokia E62 Complete Disassembly
Was du brauchst
  1. Nokia E62 Complete Disassembly, Nokia E62 Complete Disassembly: Schritt 1, Bild 1 von 1
    • To start, press one of the latches at the top of the phone to open the rear cover.
  2. Nokia E62 Complete Disassembly: Schritt 2, Bild 1 von 1
    • Carefully press the other latch.
  3. Nokia E62 Complete Disassembly: Schritt 3, Bild 1 von 1
    • Open rear cover by this side.
  4. Nokia E62 Complete Disassembly: Schritt 4, Bild 1 von 1
    • Press the three latches to open this side of the cover.
  5. Nokia E62 Complete Disassembly: Schritt 5, Bild 1 von 1
    • Remove the rear cover.
  6. Nokia E62 Complete Disassembly: Schritt 6, Bild 1 von 1
    • Removed rear cover. See the latches .
  7. Nokia E62 Complete Disassembly: Schritt 7, Bild 1 von 1
    • Remove the screws using Torx T6 screw driver.
  8. Nokia E62 Complete Disassembly: Schritt 8, Bild 1 von 1
    • Remove six T6 screws.
  9. Nokia E62 Complete Disassembly: Schritt 9, Bild 1 von 1
    • Remove the assembly. The front cover will be released.
  10. Nokia E62 Complete Disassembly: Schritt 10, Bild 1 von 1
    • The front cover released.
  11. Nokia E62 Complete Disassembly: Schritt 11, Bild 1 von 1
    • To remove the display , unscrew the T6 Torx at top.
  12. Nokia E62 Complete Disassembly: Schritt 12, Bild 1 von 1
    • CAUTION! Remove the bottom screw with T5 Torx screw driver, not T6 !
  13. Nokia E62 Complete Disassembly: Schritt 13, Bild 1 von 1
    • Carefully disconnect the Flex cable connector. Then remove the display.
  14. Nokia E62 Complete Disassembly: Schritt 14, Bild 1 von 1
    • Carefully remove the adhesive keyboard membrane.
    • You can replace it at this step if you need to.
  15. Nokia E62 Complete Disassembly: Schritt 15, Bild 1 von 1
    • You can clean the keyboard surface with alcohol, if you dropped a drink here.
  16. Nokia E62 Complete Disassembly: Schritt 16, Bild 1 von 1
    • When you replace the keyboard membrane, align the two contacts at bottom.
  17. Nokia E62 Complete Disassembly: Schritt 17, Bild 1 von 1
    • You can wash the front cover and keyboard if they are dirty.
  18. Nokia E62 Complete Disassembly: Schritt 18, Bild 1 von 1
    • Keyboard - clean it if necessary.
  19. Nokia E62 Complete Disassembly: Schritt 19, Bild 1 von 1
    • Rear side of the circuit board.
  20. Nokia E62 Complete Disassembly: Schritt 20, Bild 1 von 1
    • Speaker and antenna contacts.
  21. Nokia E62 Complete Disassembly: Schritt 21, Bild 1 von 1
    • If necessary, you can replace the joystick, the button module or the connector housing.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 18
Insgesamt: 6,976
