Zum Hauptinhalt wechseln
Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement
Was du brauchst
  1. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Battery: Schritt 1, Bild 1 von 1
    • The battery is located on the front right corner of the laptop.
  2. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: Schritt 2, Bild 1 von 1
    • With one finger on the raised grip, slide the latch towards the front of the laptop.
  3. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: Schritt 3, Bild 2 von 2
    • Pull the battery out towards the side.
  4. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: Schritt 4, Bild 2 von 2
    • Lift the battery straight up, out of the computer.
  5. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: Schritt 5, Bild 1 von 3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: Schritt 5, Bild 2 von 3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Keyboard: Schritt 5, Bild 3 von 3
    • Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
    • Fully detach the strip.
  6. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: Schritt 6, Bild 2 von 2
    • Unscrew the two screws near the top of the keyboard.
  7. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: Schritt 7, Bild 2 von 2
    • Lift the keyboard by holding the middle top of the keyboard.
    • The keyboard is still connected by a ribbon cable to the motherboard.
  8. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: Schritt 8, Bild 1 von 3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: Schritt 8, Bild 2 von 3 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: Schritt 8, Bild 3 von 3
    • Carefully pull upwards on the ribbon cable to detach.
    • Remove keyboard.
  9. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Power Button Circuit Board: Schritt 9, Bild 1 von 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement, Power Button Circuit Board: Schritt 9, Bild 2 von 2
    • Unscrew the screws on either side of the power button circuit board.
  10. Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: Schritt 10, Bild 1 von 2 Toshiba Satellite 1415-S105 Power Button Circuit Board Replacement: Schritt 10, Bild 2 von 2
    • Pull upward on the small white ribbon cable to detach from circuit board.
Abschluss
Kiril Lange
943 Reputation
9 Anleitungen geschrieben
USF Tampa, Team 3-2, Brown Fall 2014 Mitglied von USF Tampa, Team 3-2, Brown Fall 2014
USFT-BROWN-F14S3G2
3 Mitglieder
27 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 1,419
