Zum Hauptinhalt wechseln
Sony Xperia U Motherboard Replacement
Was du brauchst
  1. Sony Xperia U Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
  3. Sony Xperia U Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Remove the bottom cover of the phone using the plastic opening tool.
  4. Sony Xperia U Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the five 5.47mm and one 5.18mm Torx head screws using a Phillips #0 screwdriver.
  5. Sony Xperia U Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Carefully remove the back cover using the plastic opening tool.
  6. Sony Xperia U Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Pry up on the right side of the motherboard using the plastic opening tool.
  7. Sony Xperia U Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Carefully detach the flex cable using a pair of tweezers.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Bader
545 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 7-2, Leahy Fall 2014 Mitglied von USF Tampa, Team 7-2, Leahy Fall 2014
USFT-LEAHY-F14S7G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 2,845
