Einleitung
If the fork arm in The Buttonholer is not moving properly while being operated, chance are you need to replace the spring holding the arm.
Was du brauchst
Unscrew the screw located underneath fork arm using a Flathead screwdriver.
Raise the fork arm so that it is parallel with the upper hook.
Turn the lower hook towards you from the bottom, and remove.
Remove the old spring from the hook.
Add the new spring to the hook.
Fast fertig!
Abschluss
