Zum Hauptinhalt wechseln
Nokia Lumia 900 Motherboard Replacement
Was du brauchst
  1. Achtung: Schritt 1 stammt von einer Anleitung, die derzeit bearbeitet wird.
    Nokia Lumia 900 Motherboard Replacement, Opening The Phone: Schritt 1, Bild 1 von 2 Nokia Lumia 900 Motherboard Replacement, Opening The Phone: Schritt 1, Bild 2 von 2
    • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
    • Using the opening tool, pry the screen from the casing until they are separated from each other.
  2. Nokia Lumia 900 Motherboard Replacement, Removing the Battery: Schritt 2, Bild 1 von 1
    • Detach connector from the phone.
    • Use the opening tool to pry out battery from the phone.
    • The battery should come out fairly easily
  3. Nokia Lumia 900 Motherboard Replacement, Detach the Screen: Schritt 3, Bild 1 von 1
    • Detach Connectors that are attached from the screen to the motherboard.
    • Screen can now be removed with little effort.
  4. Nokia Lumia 900 Motherboard Replacement, Removing Rubber Gaskets: Schritt 4, Bild 1 von 1
    • Using a pair of tweezers, remove rubber gaskets that are holding the motherboard in place.
  5. Nokia Lumia 900 Motherboard Replacement, Removing the Motherboard: Schritt 5, Bild 1 von 1
    • Starting in the bottom left corner of the device, insert a wedge between the motherboard and the case.
    • Gently pull up with the wedge allowing for the motherboard to gently click out of place.
    • Gradually repeat this process around the entire motherboard until it becomes easy enough to remove completley from the casing.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Joshua Crosman
304 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 5-1, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,630
