Zum Hauptinhalt wechseln
Disassembling Planet Eclipse Etha Frame
Was du brauchst
  1. Disassembling Planet Eclipse Etha Frame, Regulator: Schritt 1, Bild 1 von 2 Disassembling Planet Eclipse Etha Frame, Regulator: Schritt 1, Bild 2 von 2
    • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
    • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
    • The macroline is the black hose connecting the regulator to the tank connection.
  2. Disassembling Planet Eclipse Etha Frame: Schritt 2, Bild 1 von 2 Disassembling Planet Eclipse Etha Frame: Schritt 2, Bild 2 von 2
    • Remove the regulator by unscrewing it in a clockwise direction.
  3. Disassembling Planet Eclipse Etha Frame, Battery and Grip Panels: Schritt 3, Bild 1 von 2 Disassembling Planet Eclipse Etha Frame, Battery and Grip Panels: Schritt 3, Bild 2 von 2
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  4. Disassembling Planet Eclipse Etha Frame: Schritt 4, Bild 1 von 1
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  5. Disassembling Planet Eclipse Etha Frame: Schritt 5, Bild 1 von 2 Disassembling Planet Eclipse Etha Frame: Schritt 5, Bild 2 von 2
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  6. Disassembling Planet Eclipse Etha Frame, Frame: Schritt 6, Bild 1 von 2 Disassembling Planet Eclipse Etha Frame, Frame: Schritt 6, Bild 2 von 2
    • Carefully disconnect the three connectors from the circuit board.
    • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
  7. Disassembling Planet Eclipse Etha Frame: Schritt 7, Bild 1 von 2 Disassembling Planet Eclipse Etha Frame: Schritt 7, Bild 2 von 2
    • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
  8. Disassembling Planet Eclipse Etha Frame: Schritt 8, Bild 1 von 1
    • Be very careful during the step to avoid damage to the solenoid or wiring.
    • Gently separate the top and bottom of the marker.
Abschluss
nicholasj6
261 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 10-42, Amido Fall 2014 Mitglied von Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 11
Insgesamt: 385
