Zum Hauptinhalt wechseln
Samsung Galaxy SIII Mini VE Battery Replacement
Was du brauchst
  1. Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: Schritt 1, Bild 1 von 3 Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: Schritt 1, Bild 2 von 3 Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: Schritt 1, Bild 3 von 3
    • Flip the phone over so you are viewing the back.
    • Using you fingernail, or an opening tool, pry open the notch that is located at the top of the phone.
    • Carefully follow you finger or opening tool around the edge of the rear casing until it has detached from the phone.
    • Set the rear casing aside for future use.
  2. Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: Schritt 2, Bild 1 von 2 Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: Schritt 2, Bild 2 von 2
    • The battery is the large grey and black rectangle.
    • Using your fingernail, or opening tool, gently pry the bottom of the battery until it pops out.
    • Place the old battery aside for now, or dispose of it properly.
  3. Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: Schritt 3, Bild 1 von 2 Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: Schritt 3, Bild 2 von 2
    • Locate your new battery.
    • Correctly orient the new battery to be inserted.
    • To orient the battery, make sure the 3 metallic bars align with the 3 prongs on the phone.
    • Gently insert the new battery into the battery slot.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Megan
1.186 Reputation
6 Anleitungen geschrieben
Michigan Tech, Team 1-8, Lauer Fall 2014 Mitglied von Michigan Tech, Team 1-8, Lauer Fall 2014
MTU-LAUER-F14S1G8
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 19
Insgesamt: 3,320
