Zum Hauptinhalt wechseln
LG Motion 4G MS770 Motherboard Replacement
Was du brauchst
  1. LG Motion 4G MS770 Motherboard Replacement, Remove the phone's back cover.: Schritt 1, Bild 1 von 1
    • Use a plastic opening tool to remove the back cover.
  2. LG Motion 4G MS770 Motherboard Replacement, Remove the battery.: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
  3. LG Motion 4G MS770 Motherboard Replacement, Remove screws.: Schritt 3, Bild 1 von 1
    • Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
  4. LG Motion 4G MS770 Motherboard Replacement: Schritt 4, Bild 1 von 2 LG Motion 4G MS770 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to remove the back trim by working around all of the edges.
  5. LG Motion 4G MS770 Motherboard Replacement: Schritt 5, Bild 1 von 2 LG Motion 4G MS770 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the volume buttons from the side.
  6. LG Motion 4G MS770 Motherboard Replacement, Speaker: Schritt 6, Bild 1 von 2 LG Motion 4G MS770 Motherboard Replacement, Speaker: Schritt 6, Bild 2 von 2
    • Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
    • Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
  7. LG Motion 4G MS770 Motherboard Replacement, Rear Facing Camera: Schritt 7, Bild 1 von 1
    • Pry slightly underneath the tab attached to the camera until it pops off.
  8. LG Motion 4G MS770 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Use tweezers to remove the camera, you will need to use some force as it is glued on.
  9. LG Motion 4G MS770 Motherboard Replacement, Motherboard: Schritt 9, Bild 1 von 1
    • Pry off the circled tabs using a plastic opening tool to release the motherboard.
  10. LG Motion 4G MS770 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Lift the motherboard off of the phone. It should come right out.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Zarna Patel
320 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 14-1, Leahy Fall 2014 Mitglied von USF Tampa, Team 14-1, Leahy Fall 2014
USFT-LEAHY-F14S14G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 1,291
