Zum Hauptinhalt wechseln
Brother PT-1290 Keyboard Replacement
Was du brauchst
  1. Brother PT-1290 Keyboard Replacement, Turn over device to remove batteries.: Schritt 1, Bild 1 von 3 Brother PT-1290 Keyboard Replacement, Turn over device to remove batteries.: Schritt 1, Bild 2 von 3 Brother PT-1290 Keyboard Replacement, Turn over device to remove batteries.: Schritt 1, Bild 3 von 3
    • Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
  2. Brother PT-1290 Keyboard Replacement, Back of device: Schritt 2, Bild 1 von 3 Brother PT-1290 Keyboard Replacement, Back of device: Schritt 2, Bild 2 von 3 Brother PT-1290 Keyboard Replacement, Back of device: Schritt 2, Bild 3 von 3
    • Remove back of device and set aside.
  3. Brother PT-1290 Keyboard Replacement, Remove screws: Schritt 3, Bild 1 von 3 Brother PT-1290 Keyboard Replacement, Remove screws: Schritt 3, Bild 2 von 3 Brother PT-1290 Keyboard Replacement, Remove screws: Schritt 3, Bild 3 von 3
    • Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
  4. Brother PT-1290 Keyboard Replacement, Remove flat panel: Schritt 4, Bild 1 von 3 Brother PT-1290 Keyboard Replacement, Remove flat panel: Schritt 4, Bild 2 von 3 Brother PT-1290 Keyboard Replacement, Remove flat panel: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
  5. Brother PT-1290 Keyboard Replacement, Remove: Schritt 5, Bild 1 von 3 Brother PT-1290 Keyboard Replacement, Remove: Schritt 5, Bild 2 von 3 Brother PT-1290 Keyboard Replacement, Remove: Schritt 5, Bild 3 von 3
    • Use a spudger to aid in removing the keyboard.
    • Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
Abschluss
Gateway, Team 1-4, Johnson Fall 2014 Mitglied von Gateway, Team 1-4, Johnson Fall 2014
GCC-JOHNSON-F14S1G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 490
