Zum Hauptinhalt wechseln
ZTE Telstra T95 Battery Replacement
Was du brauchst
  1. ZTE Telstra T95 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
    • You may also use your finger nail if you do not have a plastic opening tool at hand.
  2. ZTE Telstra T95 Battery Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
    • The battery snaps out of place and you can remove it using your fingers.
    • When you are ready to insert a battery make sure the three copper teeth on the phone are aligned with the 3 copper dents on the battery.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jeesenia Rios
300 Reputation
2 Anleitungen geschrieben
Gateway, Team 1-1, Johnson Fall 2014 Mitglied von Gateway, Team 1-1, Johnson Fall 2014
GCC-JOHNSON-F14S1G1
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 339
