Einleitung
You will be able to replace the keypad on your ZTE Telstra T95. No background information required.
Was du brauchst
Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
The battery snaps out of place and you can remove it using your fingers.
Using your a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
Unscrew the phone casing using a small screw driver. Remove the four screws on each corner on the back of the phone.
Remove front casing by sliding a plastic opening tool between the chrome layer and the top cover.
The buttons should come off with the front casing but sometimes they don't. If that is the case simply remove them using your fingers and place them with the front cover.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
