Zum Hauptinhalt wechseln
ZTE Telstra T95 SIM Card Replacement
  1. ZTE Telstra T95 SIM Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
    • You may also use your finger nail if you do not have a plastic opening tool at hand.
  2. ZTE Telstra T95 SIM Card Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
    • The battery snaps out of place and you can remove it using your fingers.
    • When you are ready to insert a battery make sure the three copper teeth on the phone are aligned with the 3 copper dents on the battery.
  3. ZTE Telstra T95 SIM Card Replacement, SIM Card: Schritt 3, Bild 1 von 1
  4. ZTE Telstra T95 SIM Card Replacement: Schritt 4, Bild 1 von 1
    • Using your a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
  5. ZTE Telstra T95 SIM Card Replacement: Schritt 5, Bild 1 von 2 ZTE Telstra T95 SIM Card Replacement: Schritt 5, Bild 2 von 2
    • Remove the SIM card by placing your index finger over it and sliding it out.
    • When you are ready to re-insert the SIM card make sure the pink side facing up.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jeesenia Rios
300 Reputation
2 Anleitungen geschrieben
Gateway, Team 1-1, Johnson Fall 2014 Mitglied von Gateway, Team 1-1, Johnson Fall 2014
GCC-JOHNSON-F14S1G1
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 755
