Einleitung
Follow these steps if you are experiencing uneven print quality or lines in your printed documents.
Was du brauchst
Turn the printer off and wait a few minutes for it to cool.
Pull the imaging unit out of the printer using bottom handle.
Use green handle on top of imaging unit to steady unit as you pull it out.
Carefully pry plastic from screw base so that the entire organic photo conductor piece slides open to the left.
Slide each toner transfer unit out separately, placing all aside except for the black toner transfer unit.
Remove these five screws from the top of the black toner transfer unit.
Remove main and smaller z-shaped plates.
Remove plastic end piece.
Gently pull out black toner roller.
Insert new roller in place of old roller turning slightly to fit.
Cover new roller with toner by rotating roller by hand.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
I need more information pertaining step 8. In order to separate the parts, in which directions should the be moved first and where is the best point to apply force ?
I need more information for step 12: I removed the old roller. Unfortunately I don't know anymore how exactly the metal discs and the white plastic rings are placed.
