Zum Hauptinhalt wechseln
Nook HD+ Antenna Replacement
Was du brauchst
  1. Nook HD+ Antenna Replacement, Antenna: Schritt 1, Bild 1 von 1
    • Pry the front frame off of the nook by wedging the plastic opening piece between the frame and the nook.
  2. Nook HD+ Antenna Replacement, Remove the screws: Schritt 2, Bild 1 von 2 Nook HD+ Antenna Replacement, Remove the screws: Schritt 2, Bild 2 von 2
    • Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Nook HD+ Antenna Replacement, Remove the chassis: Schritt 3, Bild 1 von 2 Nook HD+ Antenna Replacement, Remove the chassis: Schritt 3, Bild 2 von 2
    • Carefully remove the center chassis from the bottom frame.
  4. Nook HD+ Antenna Replacement, Dettatch battery: Schritt 4, Bild 1 von 3 Nook HD+ Antenna Replacement, Dettatch battery: Schritt 4, Bild 2 von 3 Nook HD+ Antenna Replacement, Dettatch battery: Schritt 4, Bild 3 von 3
    • Detach the battery ribbon from the motherboard.
  5. Nook HD+ Antenna Replacement, Flip the center chassis: Schritt 5, Bild 1 von 1
    • Flip the center chassis so that the screen is facing down, and the hole is positioned in the bottom right corner.
  6. Nook HD+ Antenna Replacement, Remove the antenna part 1: Schritt 6, Bild 1 von 2 Nook HD+ Antenna Replacement, Remove the antenna part 1: Schritt 6, Bild 2 von 2
    • Remove the wire from the attachment on the motherboard (this wire un-clips).
  7. Nook HD+ Antenna Replacement, Remove the antenna part 2: Schritt 7, Bild 1 von 2 Nook HD+ Antenna Replacement, Remove the antenna part 2: Schritt 7, Bild 2 von 2
    • Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten.
  8. Nook HD+ Antenna Replacement, Place new antenna.: Schritt 8, Bild 1 von 2 Nook HD+ Antenna Replacement, Place new antenna.: Schritt 8, Bild 2 von 2
    • Replace new antenna following all the steps in reverse.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Elijah Gonsalves
1.049 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Mitglied von UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,106
