Zum Hauptinhalt wechseln
Connect Four Electronic Handheld Speaker Replacement
Was du brauchst
  1. Connect Four Electronic Handheld Speaker Replacement, Ensure the device is off.: Schritt 1, Bild 1 von 1
    • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
  2. Connect Four Electronic Handheld Speaker Replacement, Removing the battery casing.: Schritt 2, Bild 1 von 2 Connect Four Electronic Handheld Speaker Replacement, Removing the battery casing.: Schritt 2, Bild 2 von 2
    • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
    • Slide the cover off and remove the battery.
  3. Connect Four Electronic Handheld Speaker Replacement, Removing/Replacing the Back Casing: Schritt 3, Bild 1 von 2 Connect Four Electronic Handheld Speaker Replacement, Removing/Replacing the Back Casing: Schritt 3, Bild 2 von 2
    • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
    • Carefully remove the back casing.
    • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
  4. Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: Schritt 4, Bild 1 von 3 Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: Schritt 4, Bild 2 von 3 Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: Schritt 4, Bild 3 von 3
    • If the speaker is in working condition, but the wires are broken or disconnected, skip this step and move on to step 5.
    • Locate the speaker on the back casing.
    • Using a spudger, wedge the speaker out of its place until it slides out.
    • Take the replacement speaker and wedge it back into its space.
  5. Connect Four Electronic Handheld Speaker Replacement, Re-Soldering the Speaker Wire: Schritt 5, Bild 1 von 1
    • Using a soldering iron, solder both red wires to their appropriate connections.
    • Be extremely careful when using a soldering iron! Contact with the tip could cause severe burns.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Wil
313 Reputation
3 Anleitungen geschrieben
Baylor, Team 8-11, Williams Fall 2014 Mitglied von Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 215
