Zum Hauptinhalt wechseln
Alcatel OneTouch Evolve Battery Removal
Was du brauchst
  1. Alcatel OneTouch Evolve Battery Removal, Locate the access tab: Schritt 1, Bild 1 von 1
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
  2. Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: Schritt 2, Bild 1 von 3 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: Schritt 2, Bild 2 von 3 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: Schritt 2, Bild 3 von 3
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
  3. Alcatel OneTouch Evolve Battery Removal, Identify the Battery: Schritt 3, Bild 1 von 1
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
  4. Alcatel OneTouch Evolve Battery Removal, Removing the battery: Schritt 4, Bild 1 von 2 Alcatel OneTouch Evolve Battery Removal, Removing the battery: Schritt 4, Bild 2 von 2
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
Abschluss
12 weitere Nutzer:innen haben diese Anleitung absolviert.
Brendan Egan
2.467 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 4-5, Miles Fall 2014 Mitglied von UMass Dartmouth, Team 4-5, Miles Fall 2014
UMASSD-MILES-F14S4G5
3 Mitglieder
12 Anleitungen geschrieben
5 Kommentare
Thanks 4 the info.
dennisp1964 - Antwort
my phone is rooted
next time i,m delete all software
now my phone show only lock screen
how to install my old software
Noushad Marshi - Antwort
Thank you very much!
Kath B - Antwort
Easy and clear instructions! I am 95 yrs old and I found your instructions wonderful! Thank you Helen Spriggs
Helen Spriggs - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 9,998
