Zum Hauptinhalt wechseln
Connect Four Electronic Handheld Back Casing Replacement
Was du brauchst
  1. Connect Four Electronic Handheld Back Casing Replacement, Ensure the device is off.: Schritt 1, Bild 1 von 1
    • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
  2. Connect Four Electronic Handheld Back Casing Replacement, Removing the battery casing.: Schritt 2, Bild 1 von 2 Connect Four Electronic Handheld Back Casing Replacement, Removing the battery casing.: Schritt 2, Bild 2 von 2
    • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
    • Slide the cover off and remove the battery.
  3. Connect Four Electronic Handheld Back Casing Replacement, Removing/Replacing the Back Casing: Schritt 3, Bild 1 von 2 Connect Four Electronic Handheld Back Casing Replacement, Removing/Replacing the Back Casing: Schritt 3, Bild 2 von 2
    • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
    • Carefully remove the back casing.
    • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
Abschluss
Wil
313 Reputation
3 Anleitungen geschrieben
Baylor, Team 8-11, Williams Fall 2014 Mitglied von Baylor, Team 8-11, Williams Fall 2014
BU-WILLIAMS-F14S8G11
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 121
